buku 1 Napisano 30 Grudnia 2011 (edytowane) U LG podświetlanie to białe OLED-y a nie kolorowe dla RGB. Szybkość matrycy będzie OK, ale czerń będzie zależeć od ilości oledowych źródeł. Podobnie jak w local-diming. I to może być tanie rozwiązanie. komunikat prasowy od LG: The panel adopts an Oxide TFT technology for backplane which is different from a Low Temperature Poly Silicon (LTPS) type generally used in existing small-sized OLED panels. The Oxide TFT type that LG Display utilizes is similar to the existing TFT process, with the simple difference lying in replacing Amorphous Silicon with Oxide. Moreover, the Oxide TFT type produces identical image quality to high performance of LTPS base panels at significantly reduced investment levels.Additionally, LG Display uses White OLED (WOLED). WOLED vertically accumulates red, green, and blue diodes. With white color light emitting from the diode, it displays screen information through color layers below the TFT base panel, which leads to a lower error rate, higher productivity, and a clearer Ultra Definition screen via the benefits of small pixels. Further, it is possible to realize identical colors in diverse angles via color information displayed through a thin layer. Lower electricity consumption in web browsing environments for smart TVs is another key strength of WOLED. Czyli zamiast drogo i małe panele LG opanował innowacyjną technologię pozwalającą na tanią produkcję dużych matryc, bez straty jakości ! Ale czy każdy sub-pixel ma swojego White OLEDa ? 3 x 1920 x 1080 = 6 220 800 szt. Bo pojedynczy WOLED może (chyba) naświetlać wiele sub-pixeli tego samego koloru. Zobaczymy 9 stycznia. Trzeba uruchomić Roberta w Vegas. LG Display's 55" OLED TV panel produces remarkable image quality with no after image due to its high reaction velocity, as well as high contrast ratio of over 100,000:1 and wider color gamut than that produced by LCD panels.OLED, a medium that controls pixels is a departure from LCD panels which utilize liquid crystals. The new technology allows light emitting diodes to self-generate light and features a reaction velocity to electric signals over 1000 times faster than liquid crystal. The environmentally conscious will also appreciate LG Display's 55" OLED TV panel. While light sources in backlight units, like LCD panels, must always be kept on, the OLED panel allows diodes to be turned on or off which enables lower power consumption than conventional LCD panels. LG Display 55" panel OLED TV daje bardzo wysoką jakość obrazu:- bez tgz. smużenia ze względu na wysoką szybkość reakcji, - wysoki współczynnik kontrastu na 100.000:1 - szerszą gamę barw niż wytwarzany przez panele LCD. OLED, to medium, które kontroluje piksele i jest odejściem od paneli LCD, które wykorzystują ciekłe kryształy. Nowa technologia pozwala diodom elektroluminescencyjnym samodzielne generowanie światła i posiada szybkość reakcji na sterujące impulsy elektryczne ponad 1000 razy większą niż ciekły kryształ. Pro-ekolodzy docenią LG Display 55" panel OLED TV. Podczas gdy źródła światła w jednostkach podświetlających, takich jak panele LCD, muszą zawsze świecić, panel OLED pozwala diodom być włączone lub wyłączone, co umożliwia niższe zużycie energii niż w konwencjonalnyvh panelach LCD. Sam w tej sprawie milczy jeszcze. EDIT 01.09.2012: Konferencja LG OLED oraz zdjęcia z IFA 2012. Niestety telewizor ma pewne problemy. Czerwień na wprost blada a pod kątem dobra (!!??) oraz pasywne 3D to nie to czego oczekujemy po najnowszych technologiach! Edytowane 1 Września 2012 przez Gmeru Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Fantom 81 Napisano 30 Grudnia 2011 Szybkość matrycy będzie OK, ale czerń będzie zależeć od ilości oledowych źródeł. Sorry ale nie rozumiem. Cechą matryc OLED'a jest to że źródłem emitowanego światła są pojedyncze punkty obrazu. Nie potrzeba żadnego podświetlenia. Więc to jest OLED czy nie? Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
lookcorner 14 Napisano 30 Grudnia 2011 Sama technologia oled jest tańsza w produkcji od lcd, jedynie stworzenie hermetycznej obudowy trochę kosztuję, jednak jak ruszy machina na całego, ceny powinny być porównywalne do dzisiejszych elsidików. Nawet stworzono już ulepszoną wersję oled o nazwie pled - zwiększona żywotność. Ja osobiście czekam aż lampy LED zadomowią się na stałe w rzutnikach, dzięki czemu raz na zawsze pozbędę się mikrusich TV Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
cles 1 Napisano 30 Grudnia 2011 Cechą matryc OLED'a jest to że źródłem emitowanego światła są pojedyncze punkty obrazu. Nie potrzeba żadnego podświetlenia. Więc to jest OLED czy nie? Tak ale LG będzie miał całą matrycę z białych pikseli a za powstanie kolorów będzie odpowiadał nałożony filtr kolorów. Samsung wypuści OLED z pikselami RGB Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
raus 145 Napisano 30 Grudnia 2011 Tak ale LG będzie miał całą matrycę z białych pikseli a za powstanie kolorów będzie odpowiadał nałożony filtr kolorów. To na kontrast nie wpłynie (bo i tak każdy piksel będzie mógł zostać zgaszony), w najgorszym razie może źle wpływać na rozdzielczość jeśli zdecydują się na inny układ subpikseli (filtrów) niż tradycyjny. Na dobrą sprawę taki ekran z filtrowanymi białymi diodami to dokładnie to samo co LCD, ale w LCD subpiksel z ciekłych kryształów reguluje (zmniejsza) ilość światła i jest praktycznie niemożliwe żeby zatrzymał całe. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Fantom 81 Napisano 30 Grudnia 2011 Tak ale LG będzie miał całą matrycę z białych pikseli a za powstanie kolorów będzie odpowiadał nałożony filtr kolorów. Poda warunkiem, że na każdy punkt na ekranie będzie 3 diody OLED (czyli po jednej na każdy subpixel RGB) ... będzie dobrze. Przynajmniej jeśli chodzi o czerń. O jasność też bym się nie martwił, diody świecą jasne i mają spory zapas "mocy" świecenia. Gorzej jeśli zastosują różnego rodzaju mieszanie w stylu jedna dioda OLDE podświetlająca kilka subpixeli. Wtedy to będzie totalna lipa. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
buku 1 Napisano 31 Grudnia 2011 (edytowane) Fantom; poczytaj LG Press Release. Uzupełniłem mój wpis wyżej. Powstaje problem; Ale czy każdy sub-pixel ma u LG swojego White OLEDa ? Bo 3 x 1920 x 1080 = 6,2208 mln szt. Czy pojedynczy WOLED może (chyba może) naświetlać wiele sub-pixeli tego samego koloru ? Stąd moje porównanie do klas Local Diming. Tego Panowie nie załapsli. Edytowane 31 Grudnia 2011 przez buku Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Fantom 81 Napisano 31 Grudnia 2011 Ale czy każdy sub-pixel ma u LG swojego White OLEDa ? No właśnie tego nikt nie wyjaśnia. Czyli idąc "teorią spiskową" pewnie nie mają się czym chwalić. Z drugiej strony jeśli filtry odpowiedzialne za kolory będą pasywne (czyli będą kolorowymi "szybkami") to nie da się zrobić inaczej jak podświetlenie każdego z subpixeli oddzielnie. Zresztą nie ma co gdybać. Przeczytamy już niedługo z relacji naocznych świadków Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
buku 1 Napisano 31 Grudnia 2011 Czy pojedynczy WOLED jako źródło światła może (chyba może) naświetlać wiele sub-pixeli ale tego samego koloru ? Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Fantom 81 Napisano 31 Grudnia 2011 Czy pojedynczy WOLED jako źródło światła może (chyba może) naświetlać wiele sub-pixeli ale tego samego koloru ? Ale wtedy te wszystki subpixele będą tego samego koloru (zakładając że barwę wprowadza "kolorowa szybka"). Mam wrażenie że czegoś nie wiemy ... Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mobor 233 Napisano 31 Grudnia 2011 Moja nastepna przesiadka to autostereoskopowy OLED Poczekam sobie...cierpliwie Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
enceladus 0 Napisano 31 Grudnia 2011 Ludzie, zastanówcie się trochę co wy wypisujecie... To oczywiste że podświetlenie będzie osobno dla każdego sub-piksela. Bo gdyby podświetlał się cały piksel to niby jakim cudem można by uzyskać na ekranie POJEDYŃCZE barwy składowe czyli RGB lub barwy na które składają się dwa kolory składowe ? Przecież jedynymi barwami w takim przypadku jakie dałoby się uzyskać byłyby czerń oraz biel. Pomyślcie trochę zanim coś napiszecie Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
binary 741 Napisano 31 Grudnia 2011 (edytowane) http://www.oled-display.net/background-informations-about-lg-displays-woled-tv-technology/ A tymczasem Szczesliwego Nowego roku i szampaskiej zabawy. Edytowane 31 Grudnia 2011 przez binary Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
JackS. 6 Napisano 31 Grudnia 2011 Fantom; poczytaj LG Press Release. Uzupełniłem mój wpis wyżej. Powstaje problem; Ale czy każdy sub-pixel ma u LG swojego White OLEDa ? Bo 3 x 1920 x 1080 = 6,2208 mln szt. Czy pojedynczy WOLED może (chyba może) naświetlać wiele sub-pixeli tego samego koloru ? Stąd moje porównanie do klas Local Diming. Tego Panowie nie załapsli. Wygląda na to, że Full HD OLEDY LG będą składały się z 4 x 1920 x 1080 = 8294400 OLEDów, bo matryca będzie typu white-RGBW. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
enceladus 0 Napisano 31 Grudnia 2011 http://www.oled-display.net/background-informations-about-lg-displays-woled-tv-technology/ A tymczasem Szczesliwego Nowego roku i szampaskiej zabawy. Z tego artykułu można wywnioskować że OLED firmy LG będzie mieć sporo dłuższą żywotność niż OLED Samsunga. Ciekawe tylko który będzie oferował lepszą jakość obrazu Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
buku 1 Napisano 2 Stycznia 2012 Będą cztery pixele !!! http://www.engadget.com/2012/01/01/lg-details-55-inch-oled-tv-will-show-off-its-true-colors-at-ces/ What sets LG's TV picture apart from other OLED TVs is 4-Color Pixels and Color Refiner which work together to generate natural and accurate colors that are sharp and consistent. The 4-Color Pixels feature allows for more accurate color depiction by using a set of four colors (red, green blue and white) in comparison to the RGB setup used by other OLED TV manufacturers. Color Refiner ensures consistency in colors from a wider viewing angle via an LG algorithm which improves and refines hues and tones. This is in contrast to other OLED TVs which often exhibit drastic changes in hues from different viewing angles and abnormal color gamut. Boasting an infinite contrast ratio, LG's OLED TV exhibits vivid colors and the smallest details regardless of the overall luminance of the on-screen image. In turn, colors and details throughout an entire image are preserved with utmost clarity and sharpness, even when displaying scenes with dark lighting. Such color capabilities are technically impossible with LED and LCD display panels. And at 1,000 times faster than LED/LCD displays, LG's OLED TV shows crystal clear motion without any blurring or bleeding. And LG's OLED TV is as aesthetically pleasing as it is technologically sophisticated. LG's Slim and Narrow Bezel design gives the TV a sleek, minimal look and at only 4 mm thin and a mere 7.5 kg, LG's OLED TV practically blends into the wall. No i o niskich kosztach czytamy: "Working closely with LG Display, we have a product which not only delivers on all the advantages of OLED over LCD but at a significantly lower cost than what could be achieved using existing OLED manufacturing technologies," said Havis Kwon, President and CEO of LG Electronics Home Entertainment Company. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gmeru 2 225 Napisano 3 Stycznia 2012 I po polsku: Nowy telewizor OLED 55" Drugą zapowiedzianą właśnie nowością, która będzie miała swoją oficjalną premierę w trakcie CES, jest 55-calowy telewizor OLED – największe tego typu urządzenie na świecie. Wyposażony w technologie 4-Color Pixels i Color Refiner model to prawdziwa rewolucja na rynku. OLED łączy w sobie zalety paneli LCD/LED i plazm. Oferuje żywe, jasne kolory. Jednocześnie jest nawet tysiąc razy szybszy niż typowe ekrany LCD. Dzięki temu oglądanie dynamicznych scen to sama przyjemność. Obraz pozostaje wtedy ostry. Zapowiadany telewizor ma tylko 4 mm grubości i waży raptem 7,5 kg. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
binary 741 Napisano 3 Stycznia 2012 Będą cztery pixele !!! czyzby? No to moze jeszcze raz, skoro nie wszyscy przyjrzeli sie dokladnie obrazkom : Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 3 Stycznia 2012 Jak to na zdjęciu jest 55", to ta Koreanka ma 2.5 m wysokości ! Ściema jakaś ! Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
Gmeru 2 225 Napisano 3 Stycznia 2012 Oj tam trzeba pobudzić wyobraźnię. Kolory takie będą Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
binary 741 Napisano 3 Stycznia 2012 Bodex Ciekaw jestem czy jakby ja dali rozneglizowana to tez bys spostrzegl? Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
enceladus 0 Napisano 3 Stycznia 2012 Kiedy ten CES...kiedy ten CES...KIEDY TEN CEEEEEEEEEESSSSS !? SZYBCIEJ KURDE NO !!!!! Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
piotr_the 1 Napisano 3 Stycznia 2012 Nic z tego nie rozumie, jedna dioda led? 4 subpixele? może lcd podświetlany 1 pixel 1 diodą led białą, czy dioda led biała i na niej lunimofor dla uzyskania koloru coś jak w plazmie chyba? Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
JackS. 6 Napisano 8 Stycznia 2012 Jak to na zdjęciu jest 55", to ta Koreanka ma 2.5 m wysokości ! Ściema jakaś ! Wydaje Ci się, że wysokość ekranu 55-calowego telewizora to ponad metr? Taki ekran ma 68,5 cm wysokości. A ta Koreanka nie wygląda, aby miała więcej niż 160 cm. Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
pmcomp 1 499 Napisano 8 Stycznia 2012 Jak to na zdjęciu jest 55", to ta Koreanka ma 2.5 m wysokości ! Ściema jakaś ! Nie może być taka wysoka bo ... ona jest dodawana w gratisie . Pozdro Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
