mjasinsk 162 Napisano 31 Sierpnia 2012 (edytowane) http://www.networked...d.php?tid=62764 No to muszę przyznac jest duża niespodzianka. Specyfikacja daje wyobrażenie o C-400 który pewnie koło grudnia lub na CES zostanie zaprezentowany. Siedze trochę na ich forum i musze przyznac sprawnie utrzymywali tajemnicę. Trochę szkoda że nie ma RF ale tak po za tym wygląda to nieźle. Obudowa prosta jak zwykle u Syabas dlatego RF byłby konieczny. Zintegrowanie z IPAD szkoda że póki co nie z Android. Widać które rynki mają preferencje Edit: 2.09.2012: Pierwszy player 3D na Sigmie SMP8911 już niedługo na rynku. Syabas has shown a new Popcorn Hour in front of media at the IFA convention in Berlin. The device is labeled A-400 will be considerably faster than current machines and fully compatible with 3D videos. It’s a known problem among geeks. We love to collect digital media but where do we put it? A central NAS is often the most practical option but setting it all up and buying the right equipment can prove quite the hassle. Syabas tries to offer a simple yet powerful solution with their lineup of Popcorn Hours and we’re about to welcome a new member: the A400. Popcorn Hour A-400 is the successor of the A-300 (1 year old) and differentiates itself with faster hardware and better connections. The A-400 is powered by a Sigma SMP8911 dual-core CPU running at 800MHz. RAM has stayed the same with 512MB DDR2 and 256MB of flash memory. Syabas’ specsheet comparison between previous and new products reveals that the A-400 will be the first with eSATA and SD Card support. Users can also connect HDDs easier using the Quick Dock feature, admittedly adding storage was never difficult in the first place. Also new is the ability to control the Popcorn Hour using any tablet or smartphone eliminating that pesky remote that dumped the experience of previous models. The case is more cube shape than before but otherwise remains largely similar. Syabas has chosen for a completely passively cooled design without fans disturbing users from movies or TV Shows. Cooling slots have moved from the side to the back, which is also where all the connections are. Users can transfer content in lightning speed using USB 3.0 or eSATA, and of course the A-400 also functions as a NAS. Syabas wants to release the Popcorn Hour A-400 around November this year for a price of 279 euro (300 USD). Their pro user option C-400 is missing from the company’s roadmap and appears discontinued. Edytowane 2 Września 2012 przez Gmeru Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mobor 233 Napisano 31 Sierpnia 2012 Wszystko łądnie pieknie tylko jak to będzie działać....? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 31 Sierpnia 2012 grunt ze jest jak będzie działać to się przekonamy Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
pmcomp 1 499 Napisano 1 Września 2012 (edytowane) Bedzie dzialc tak jak zwykle czyli ... FW dopracują po ok. 12-u miesiącach. Ja się nie podniecam i zostaje przy tym co mam czyli Dune H1/ Popcorn C-200 plus OPPO 95 do CD/DVD/BD/3D i LINN Majik DS do muzy strumieniowej od 16/44 do 24/192. A teraz zakupilem małą niespodzianke ktorej Mega-Test juz niedlugo. Pozdro Edytowane 1 Września 2012 przez pmcomp Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 1 Września 2012 LINN Majik DS do muzy strumieniowej od 16/44 do 24/192. Gdyby skąpi Szkoci pozwolili wejśc do niego na DAC z innych źródeł, to byłaby fajna maszynka, a tak ... Korzystasz z tego DAC-a , czy z jakiegoś zewnętrznego ? Sorry za OT. A400 pewnie będzie fajny Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 1 Września 2012 a skoro już tak offtopicujemy to lepiej takiego linn'a kupowac czy ampli strumieniujące flac'i??? Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 1 Września 2012 Lepiej preamp-procesor z USB i z siecią, ale to wg. wielu nie gra w ogóle ... :) (przez zazdrość tak piszą) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
HDev 32 Napisano 1 Września 2012 A400 działa, można podejść na ich stoisko i obejrzeć. Obudowa projektowana przez Silverstone, z daleka nic takiego, w ręku czuć różnice. Oprogramowanie praktycznie takie samo jak w A300/C300 więc nie trzeba będzie czekać na dopracowanie softu. JukeBox dostał obsługę seriali. A po sambie ma wyciągać transfery na poziomie 40MB/s. To aktuart trzeba będzie zweryfikować. No i VXP, którego jeszcze dziś na IFA nie byli w stanie do końca zaprezentować... Pomysły na wersję z wbudowanym DAC z jakiejś wyższej półki też chodzą po głowie producentowi.. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 1 Września 2012 Skoro juz podeszliście na ich stoisko to zerknijcie jeszcze na Dune bo oni zdaje się nie podali w leaflecie na czym jedzie dune HD MAX 3D Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
HDev 32 Napisano 1 Września 2012 MAX 3D na SMP8672, z budżetowej linii. Pierwszy w kolejce do sprzedaży jest jednak Dune Base 3D (!), bez napędu BD, także z 8672. Być może będzie na koniec października w sklepach. Design bez zarzutu, trzyma wzornictwo MAX/DUO. Max 3D jest nieco bardziej kontrowersyjny. Dune planuje wykorzystać możliwości 3D procesora (w cześci obsługi GUI/menu) więc można się będzie spodziewać nowego intrerfejsu. No i jeżeli chodzi o oprogramowanie, to planują nieco niezpodzianek w temacie serwisów internetowych... Oprócz tego modele TV-403D, TV-203D, TV-103D.. Skany ulotek mogę udostępnić dopiero w PN. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
HDev 32 Napisano 1 Września 2012 W temacie nowych odtwarzaczy BD, do których zalicza się takze MAX 3D gorący staje sie temat zabezpieczeń Cinavia. Polecam lekturę: http://www.cinavia.com/languages/polish/index.html Sprawa z tego roku, dotyczy nowych konstrukcji. Może być tak, że albo BD drive, albo MKV... Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 1 Września 2012 Dzięki za info...ale skoro nie ma 89.... w Dune to raczej słabiutko.... Z tego wynika, że PCH ma szansę być znowu przez chwilę liderem na rynku bo na Dune HD Pro raczej nie ma co liczyć. Nie róży bez kolców bo PCH ma BD Menu lite co dla mnie jest słabe niestety no i fora spekulują ze VXP będzie przy tej cenie z ograniczoną funkcjonalnością (podobno sigma życzy sobie niezłą kase za pełną funkcjonalnośc procka cokowliek by to nie znaczyło). Dedykowana app na ipad i na androida w przyszłości to fajna rzecz ale wszystkie te playery niestety są kulawe. Każdemu czegoś brakuje żeby uznać go za produkt kompletny (pomijam jakość, GUI itp) Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
HDev 32 Napisano 1 Września 2012 Dune PRO jak co roku stoi w gablotce. Ale kto zna historię, nie eksytuje się już tym projektem. VXP ma wiele implementacji. Jest obecne w innych układach Sigma dla czytników BD (raczej tych klasy premium), choć producenci urządzeń nie zawsze piszą że to "VXP". Implementacja w 891x jest dość pełna, oprócz bazowych funkcji skalowania obejmuje cztery algorytm, których działanie można regulować stopniowo: - Adaptive Contract Enhancement - Motion and Edge Adaptive Deinterlacing - Film Cadence Detection - Adaptive Debanding Algorytmy działają dla materialów 2D i 3D, ponoć wyraźnie poprawiając jakośc obrazu 3D, zwiększając czytelność i ilość szegółów. Generalnie procesor jest w stanie wykonywać operacje i obliczenia w czasie rzeczywistym dla każdej klatki. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 1 Września 2012 Wymuszą CINAVIĘ przy napędach na 100% bo jest mocna presja. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
HDev 32 Napisano 1 Września 2012 (edytowane) ... i tu pojawia sie pytanie za 100pkt. Co w związku z tym z Dune Max 3D? Edytowane 1 Września 2012 przez HumanMedia Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mobor 233 Napisano 2 Września 2012 No to Dune zawiodło w tym roku. Po cichu liczyłem na obiecywane board'y do serii smart z Sigmą 89xx Trudno - ich kłopot. Zobaczymy jak będzie latał A-400 - w tej chwili jedyne sensowne rozwiązanie do 3D Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
pmcomp 1 499 Napisano 2 Września 2012 (edytowane) Gdyby skąpi Szkoci pozwolili wejśc do niego na DAC z innych źródeł, to byłaby fajna maszynka, a tak ... Korzystasz z tego DAC-a , czy z jakiegoś zewnętrznego ? Sorry za OT. A400 pewnie będzie fajny Chcesz mieć wejście na DAC to kup wyższy model. Gram z DACa wbudowanego i jest miodzio na Unison Research S6 i 30-o letńich Harbeth Monitor HL MkIII. Jako zewnętrznego DACa używam czasami Tag McLaren AV32R, ma tryb 24/192 po wejsciach cyfrowych i jest to bardzo dobry DAC do stereo pomimo ze ten klocek to procesor i preamp do kina domowego. Pozdro Edytowane 2 Września 2012 przez pmcomp Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
pmcomp 1 499 Napisano 2 Września 2012 (edytowane) a skoro już tak offtopicujemy to lepiej takiego linn'a kupowac czy ampli strumieniujące flac'i??? Ampli strumieniujace to nieporozumienie jeśli mowimy o stereo i patrzymy przez pryzmat jakosci dźwieku. LINNa kupiłem z pelna swiadomoscia i odpowiedzialnoscia co kupuje i jak bede go sluchal. To ze nie ma wejsc cyfrowych to maly Pan Pikus ale ... nie ma zadnego portu USB, he, he. Gra tylko material z sieci LAN i radio internetowe co mi akurat bardzo odpowiada. Ja caly moj multimedialny material trzymam na dwóch NASach. Sterowanie przy pomocy iPada i firmowego pilota to bajka. LINN ma dwie pary regulowanych wyjść analogowych i ja z tego korzystam. A jakoscia dźwięku oczywiście zabija wszystkie źrodla ktore mam czyli np. CECa 51 MkII czu OPPO 95. Pozdro Edytowane 2 Września 2012 przez pmcomp Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 2 Września 2012 no tak pmcomp ale tutaj piszesz o zestawie dla trochę lepiej niż średnio zarabiających bo wymusza albo dwa zestawy kino domowe i stereo albo kompromis. I teraz jeżeli pomiędzy Twojego Linna wpiąłbym ampli to cała zabawa nie ma sensu i tak czy siak grało by to podobnie jak wewnętrzna obróbka w ampli. Linn niestety się ceni. Pytanie też o ile Linn będzie lepszy od obecnie wielu na rynku markowych odtwarzaczy sieciowych. Ale to w sumie pytania w powietrze bo odsłuch bo jakość źródła itd itd...dobra ja już kończę offtopa.... na temat a400 na forum nmt rozgorzała już poważna dyskusja. Dzisiaj mają się pojawic filmy od producenta prezentujące szczegóły produktu i nowy GUI Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
pmcomp 1 499 Napisano 2 Września 2012 no tak pmcomp ale tutaj piszesz o zestawie dla trochę lepiej niż średnio zarabiających bo wymusza albo dwa zestawy kino domowe i stereo albo kompromis. I teraz jeżeli pomiędzy Twojego Linna wpiąłbym ampli to cała zabawa nie ma sensu i tak czy siak grało by to podobnie jak wewnętrzna obróbka w ampli. Linn niestety się ceni. Pytanie też o ile Linn będzie lepszy od obecnie wielu na rynku markowych odtwarzaczy sieciowych. Ale to w sumie pytania w powietrze bo odsłuch bo jakość źródła itd itd...dobra ja już kończę offtopa.... na temat a400 na forum nmt rozgorzała już poważna dyskusja. Dzisiaj mają się pojawic filmy od producenta prezentujące szczegóły produktu i nowy GUI Masz rację. Ja szulałem takiego kompromisu stere/kino domowe przez 10 lat samemu sobie próbując udowodnić ze sie da i jest dobrze. W efekcie w zeszlym roku oba systemy sie odseparowaly. Mim zdaniem sie nie da. Zawsze bedzie kompromis. A co do LINNa i jakosci dzwieku to nie jest przeciez jedyna sluszna opcja. Cos innego za transport i dobry zewnetrzny DAC i jedziemy. Dla mnie LINN polaczyl jakosc dxwieku, [beeep]ista funkcjonalnosc, latwosc obslugi ze sposobem grania i magazynowańia materialu jaki preferuje. Ot i tyle. Mozna grac z notebooka przez super DAC. Jak napisalem w przyszlym tygodniu czyms Was zaskocze, klocek juz do mnie jedzie. Pozdro Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 2 Września 2012 W temacie nowych odtwarzaczy BD, do których zalicza się takze MAX 3D gorący staje sie temat zabezpieczeń Cinavia. Polecam lekturę: http://www.cinavia.com/languages/polish/index.html Sprawa z tego roku, dotyczy nowych konstrukcji. Może być tak, że albo BD drive, albo MKV... Póki co, to atakują urządzenia na fizyczny krążek, grożąc sankcjami licencyjnymi BD za brak w firmware osławionej CInavii, która miała już być wszędzie od wiosny. Jak dobiorą się do segmentu NMP, to biadoleniu nie będzie końca, gdyż chodzą słuchy, że w udoskonalonej wersji nawet zmiana kontenera nic nie pomoże. Teraz dla wielu aktualizacja firmware może nie być powodem do radości ... A scenariusz będzie taki: atrakcyjny tytuł będzie tak spreparowany, że nie będzie latał nigdzie bez aktualizacji. Pobranie Cinavii na player w takim pakiecie aktualizacyjnym będzie więc "koniecznością". Koniec radosnej zabawy. 1 Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mobor 233 Napisano 2 Września 2012 Przesadzasz Waść Karawana jedzie dalej Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 2 Września 2012 no i jest też wyjaśnienie Wernera że nie mamy sie co spodziewac C-400 właśnie ze względu na cinavie (przynajmniej na ta chwilę nie ma go w planach) Szkoda wielka szkoda. To tez oznacza, że chyba nie ma się co spodziewać dune hd max w nowych odsłonach oprócz wyklepania poprzednika w postaci 3d max 3d Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
BoDeX 121 Napisano 2 Września 2012 Pierwszy player 3D na Sigmie SMP8911 już niedługo na rynku. Syabas has shown a new Popcorn Hour in front of media at the IFA convention in Berlin. The device is labeled A-400 will be considerably faster than current machines and fully compatible with 3D videos. It’s a known problem among geeks. We love to collect digital media but where do we put it? A central NAS is often the most practical option but setting it all up and buying the right equipment can prove quite the hassle. Syabas tries to offer a simple yet powerful solution with their lineup of Popcorn Hours and we’re about to welcome a new member: the A400. Popcorn Hour A-400 is the successor of the A-300 (1 year old) and differentiates itself with faster hardware and better connections. The A-400 is powered by a Sigma SMP8911 dual-core CPU running at 800MHz. RAM has stayed the same with 512MB DDR2 and 256MB of flash memory. Syabas’ specsheet comparison between previous and new products reveals that the A-400 will be the first with eSATA and SD Card support. Users can also connect HDDs easier using the Quick Dock feature, admittedly adding storage was never difficult in the first place. Also new is the ability to control the Popcorn Hour using any tablet or smartphone eliminating that pesky remote that dumped the experience of previous models. The case is more cube shape than before but otherwise remains largely similar. Syabas has chosen for a completely passively cooled design without fans disturbing users from movies or TV Shows. Cooling slots have moved from the side to the back, which is also where all the connections are. Users can transfer content in lightning speed using USB 3.0 or eSATA, and of course the A-400 also functions as a NAS. Syabas wants to release the Popcorn Hour A-400 around November this year for a price of 279 euro (300 USD). Their pro user option C-400 is missing from the company’s roadmap and appears discontinued. Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
mjasinsk 162 Napisano 2 Września 2012 (edytowane) No i jednak cinavia miesza. Na izraelskim forum pojawił sie opis, jak juz wyzej cytowalem, z ich wizyty na ifa 2012. Opis dotyczy dune i a-400. Jest tam tez fragment z czegoś w rodzaju wywiadu z ludzmi z dune z ktorego wynika ze hd max 3D jezeli pojawi sie to dopiero w grudniu ale na ta chwile nie zaprezentowali nawet funkcjonujacego sampla bo nie sa w stanie ocenic jaki procesor zastosuja w maxie i tym samym w hd pro. Rozwazaja nawet cos spoza sigma i realtek (!). To chlopaki z syabas pewnie sie ciesza bo zostali dosyc samotni na rynku przez chwile. Na targach wogole nie bylo innych producentow liczacych sie w branzy co zreszta nie jest dziwne bo wystarczy sledzic ich strony internetowe. A przepraszam chyba byl med8ver ze swoim latajacym spodkiem Edytowane 2 Września 2012 przez mjasinsk Cytuj Udostępnij tę odpowiedź Odnośnik do odpowiedzi Udostępnij na innych stronach
