- 0
Obserwujący
0
KTOKOLWIEK MA TELEWIZOR (NTSC) Z USA i ma problem z odbiorem sygnału w Polsce
Pytanie zadane przez
oaksquare
5 odpowiedzi na to pytanie
Obserwujący
0
AF-8000HD CI w polsce AF 8800
Fully Compliant to MPEG-2 Digital standard
Fully Compliant to MPEG-4 part10 AVC HD/H, 264 standard
Fully Compliant to DVB-S/S2 satellite standard
Various Video Display format with PAL/NTSC/480p/576p/720p/1080i 50/60Hz support
* Main System Resource
CPU/Decoder :
CPU Speed :
Flash Memory :
SDRAM :
EEPROM :
* Conditional Access Interface
PCMCIA : 2 Slot of DVB CI standard (Type l or ll)
Smart Card Reader :
* RF Modulator (built in OFDM tuner)
RF-Connector : 75ohm, IEC 169-2, Male/Female
Frequency : 470 to 860MHz
Input Connector :
IF Frequency Range :
Output Channel : CH21~69 for the Demodulator
TV Standard : PAL BG/I/Dk, NTSC
Preset Channel : CH38(or TBD)
Changeable by Menu
* MPEG Transport stream & Audio / Video Decoding
Transport stream : MPEG-4 Part10 AVC/H.264 HD HP@L4.0 1920x1080 @ 50Hz
Profile Level : MPEG-2 HP@HL.MPEG-4 Part10 AVC/H.264 HD MP@L4.0
Input Rate : Maximum 90Mb/s
Aspect Ratio : 4:3, Letter Box, 16:9
Video Resolution : 1920x1080i, 1280x720p, 720x576p @ 50/60Hz
Audio Decoding : Dolby Digital, MPEG-1 Layer 1,2, MPEG 2/4 AAC
Audio Mode : Mono, Left, Right, Streo, Dilby Digital
Sampling Rate :
Graphic engine :
* Power Supply
Input Voltage : AC 90-250V ~ 50/60Hz
Type : SMPS
Power consumption : Maximum 55Watts
Protection : Separate internal Fuse
* Operation Environment
Operating Temperature : +5C ~ +50C
Storage Temperature : -40C ~ +65C
* Physical Dimension
Size (W x D x H) : 360x230x70[mm]
Weight(net) : 2.0Kg[/size]
