jaro_kr
HDI Dune - firmware
Version "121018_0846"
http://dune-hd.com/firmware/
dotyczy modeli:
Dune HD TV 301
Dune HD TV 101
Dune HD Lite 53D
Dune HD Duo
Dune HD Max
Dune HD Smart B1
Dune HD Smart D1
Dune HD Smart H1
Dune HD Base 3.0
Dune BD Prime 3.0
Niewielkie zmiany od ostatniej wersji: 120815_2150
- NOTE: This is a minor update to 120815_2151.
- Dune HD TV models: Bugfix: Vidimax application could report "error 7" in
some cases during playback.
- Bugfix: fixed problem with the playback of certain MMS URLs (the problem
appeared in the firmware version 120608_1420_beta).
- Bugfix: playback of MPEG-TS streams w/o audio and with temporary audio
dropouts could cause problems. (This includes playback of multicast, HLS,
DVB MPEG-TS streams.)
- Bugfix: playback of media content via HTTP protocol could cause hangup in
some cases (e.g. when the server did not respond).
- HLS playback improvements:
- By default, the initial quality is now chosen based on the previous
statistics (remembered till reboot).
- Various performance and stability improvements.
- Bugfix: too long HLS URLs were refused to play.
- media_url: 'hls_initial_bandwidth' parameter extended with new possible
values: 'auto' and 'auto_high'.
- More details: http://dune-hd.com/s...c/media_url.txt
- Improvements in API for PHP plugins:
- Default PHP plugin operation timeout increased to 60 seconds.
- Bugfix: PHP plugin operation was handled in wrong way in some cases.
- Bugfix: EPG OSD column had wrong title in some cases.
- Dune HD TV models: Improvements in API for HTML+JS applications:
- Bugfix: when playing HLS stream, read error events could be wrongly
generated even in the absence of any errors.
nie zauważyłem jakichś istotnych zmian - instalowałem bezpośrednio z netu ...
Mam.
Być może poprawili dźwięk z TV101 jak piszą, nie sprawdzałem bo teraz wykorzystuję to maleństwo gdzie indziej.
Moze ktos sprawdzic czy faktycznie poprawili dzwiek dd thd i dts hd na HD TV 101, HD TV 301
Edytowane przez endryu
Nie ma takiego problemu.
Chyba ze ten dysk udostepniasz gdzies po niewydolnej sieci.
