marasw
problem z mkv lg ld650
Witam. Mam problem z plikami mkv. Wiem ze tv nie odtwarza plikow z dzwiekiem DTS. Ok, mozna to przerobic na AC3.
Nie rozumiem natomiast dlaczego nie odtwarza niektorych plikow mimo dzwieku ac3. Podaje dane pliku odtwarzanego i nieodtwarzanego. Moze ktos mi wytlumaczy w czym problem?? Pozdrawim
np:
Plik odtwarzany:
Pulp Fiction (1994) 1080p\Pulp Fiction (1994) 1080p.mkv
General
Complete name : L:\Filmy\Pulp Fiction (1994) 1080p\Pulp Fiction (1994) 1080p.mkv
Format : Matroska
File size : 14.3 GiB
Duration : 2h 34mn
Overall bit rate : 13.2 Mbps
Encoded date : UTC 2011-03-24 18:55:09
Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video #1
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 34mn
Bit rate : 11.2 Mbps
Nominal bit rate : 11.5 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.299
Stream size : 12.1 GiB (85%)
Writing library : x264 core 80 r1376M 3feaec2
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=esa / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=1 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=4 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=11480 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:0.60
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 2h 34mn
______
Plik nieodtwarzany:
Imię Róży (1986) 720p\Imię Róży (1986) 720p.mkv
General
Complete name : L:\Filmy\Imię Róży (1986) 720p\Imię Róży (1986) 720p.mkv
Format : Matroska
File size : 6.05 GiB
Duration : 2h 11mn
Overall bit rate : 6 574 Kbps
Encoded date : UTC 2011-03-25 07:46:54
Video #1
Format : AVC
Format settings, ReFrames : 4 frames
Duration : 2h 11mn
Bit rate : 5 803 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.860
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.275
Stream size : 5.33 GiB (88%)
Writing library : x264 core 104 r1703 cd21d05
Encoding settings : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=10 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=64 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 11mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 422 MiB (7%)
Title : AC3 5.1@448 (original)
Audio #3
Format : AC-3
Codec ID : A_AC3
Duration : 2h 11mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Stream size : 181 MiB (3%)
Title : Commentary Track
Text #4
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
witam,
posiadam lg bd550 i też nie odtwarza mi niektórych plików co ciekawe po "przeleceniu" programem mkvmerge GUI stara wersja, problem znika myślę że to jakiś problem w kompresji pozdrawiam
Trochę późno na odpowiedź, ale może jeszcze ktoś kupuje ten TV.
Mkv śmiga elegancko bez problemów, jedyny problem to odjezdzajace napisy, ale wydaje mi się że to problem samych napisów.
