Hadiem
HDI Dune Pro - Hi-End'owy odtwarzacz multimedialny
Najnowsze dzieło HDI
Hi-End Features
* Hi-End power supply: high-performance large toroidal power transformer ensures a low level of interference in the power supply section and prevents possible distortions in the analog audio output, making the sound more clear and transparent, making music images articulated, precise and focused, and making the video more vivid and intense.
* Hi-End audio outputs: the highest quality balanced XLR stereo outputs as well as the analog 7.1 multichannel RCA outputs, served by a high performance stereo DAC WM8741 from Wolfson Microelectronics (supports from 16 to 32 bits and sampling rates up to 192 kHz).
* Balanced AES/EBU digital output: AES/EBU supporting PCM-encoded audio at 48 kHz or CD-audio at 44.1 kHz can be used to deliver digital stereo sound of the highest quality.
* High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey's Audio APE, WAV/PCM, DTS, etc).
* Big weight: big weight of the chassis and solid body provides a low vibration level of the optical disc in the drive as well as the internal HDD, minimizing the level of the disc tremor, and allowing to read data with higher accuracy.
* IR input: get more flexibility for player installation (connect an external IR eye) or connect the player to external control platforms.
* RS-232 control port and 12V trigger input: even more flexibility for integration of the player with external control platforms.
* PURE AUDIO button on the front panel: listen to the music directly, with video output electronics disabled, that helps to get even better audio quality.
* DIMMER button on the front panel: control the brightness of the built-in display or turn it off completely.
* Detachable 19" rack brackets: put the player into a standard rack mount.
Media Player Features
* The newest Sigma Designs 8642 media processor: enjoy excellent playback and performance of interactive features.
* Blu-ray and DVD player: play Blu-rays and DVDs (plus Audio CD and data discs with video/music/photo files).
* HDD player: connect an HDD to the player and play content directly from the HDD.
* Network player: connect the player to a local network and play content directly from PC or NAS (UPnP, SMB, NFS).
* MKV player: play HD and SD video in a popular MKV format and other modern video file formats, including top quality HD video with very high bitrate.
* RealD: watch 3D video in this ultra modern format used in cinema for the latest movies.
* HD audio: enjoy top-quality audio tracks (Dolby True HD, DTS HD Master Audio, LPCM, FLAC).
* 4 USB ports: conveniently connect HDDs, USB flash drives, USB card readers and other USB storage devices.
* HDD rack with hot swap function: easily and quickly insert and exchange internal 3.5" SATA HDD.
* SD card slot: easily play media files on SD memory cards from your camera or other devices, or use an SD memory card as a local or system storage (required for BD Live function).
* HDMI 1.3: ensure the best possible quality of HD video and HD audio.
* A rich set of standard A/V connectors: use S/PDIF optical audio, stereo audio, component video, composite video outputs to easily connect any A/V equipment.
* Extended support for Dolby True HD and DTS HD Master Audio: output bitstream (up to 7.1 channels) or decode (up to 7.1 channels) for maximum flexibility when connecting audio equipment, and for extended support of advanced playback features (such as Picture-in-Picture).
* High-quality music playback: play very high-quality (up to 192 Khz / 24-bit) music files in various formats (FLAC, Monkey’s Audio APE, WAV/PCM, DTS, etc).
* Playlists: build playlists from your folders, use your own playlists, use repeat and shuffle functions.
* Video output flexibility: output video in any resolution and format (from SD to 1080p, 24p/PAL/NTSC).
* Upscaling: high quality upscaling of DVD and any other SD video content to Full HD (1080p) or other HD resolution.
* File browser: convenient file browser with powerful file management (copy, move, delete, rename, organize, sort).
Więcej na stronce HDI
Oj będzie co oglądać na IFA ;)
Edytowane przez Hadiem
Na ostudzenie ewentualnych zapędów,
Prijs € 1990, - en leverbaar w październiku.
Czyli - € 1990 = 7 902,66957 złotego polskiego
To już wolę dokupić do C-200 obudowę i zewnętrzny przetwornik DC/AC i będę miał Hi-End za mniejsze pieniądze o takiej samej funkcjonalności.
Pozdrawiam,
AndrzejS@
Edytowane przez andsie1
Czołg - brzydki jak .... a bebechy takie same .
Pozdrawiam,
AndrzejS@
Gdzie można kupić taką obudowę do A-200 ?
Obudowa nazywa się HFX® mini - acryl black tu i kosztuje 285,00EUR + wyświetlacz iMon VFD and IR-89,00EUR tu. + przesyłka około 15 EURO.
Taka:
lub taka:
Pozdrawiam,
AndrzejS@
Wracając do tematu PROtwora - co on ma pod tymi potwornie brzydkimi klapami ? Po dwie szuflady na HDD i napędy ? :)
Może ktoś ma fotkę bebechów ?
Cena kosmiczna i co poza tym ?
Wyjscia analogowe i kieszenie na dysk i naped blu ray. Szkoda kasy.
Ja w swoim pch c200 wstawilem naped blu ray od przodu i wyciagnalem na zewnatrz z tylu wyciagniety kabelek pod HDD. Obudowa zamknieta tak jak powinna a podmieniam dyski kiedy chce. Nie widze zadnego problemu a koszt > podstawowej wersji PCH 200.
Wg mnie ten nowy model to wersja dla snobow z przesytem $-ow
braavoo
braavoo
Kolego a gdzie estetyka. Czy tylko chodzi o kasę ?.
Najnowsze dzieło HDI posiada nowy procesor obróbki Sigma Designs 8642 który jest szybszy i posiada więcej funkcji.
Ja natomiast nie jestem w stanie akceptować obudowy C-200 (straszna tandeta).
Dlatego przymierzam się do zakupu HFX mini - acryl black mimo, że koszt takiej operacji będzie mnie kosztował ponad 1 000 zł.
Pozdrawiam,
Andrzejs@
Ciekawe czy ten player będzie pozbawiony przypadłości aktualnych odtwarzaczy Dune, czyli głośnego łupnięcia na wyjściach analogowych w chwili włączania / wyłączania urządzenia. Nie wiem czy komuś przez to spaliły się już głośniki / końcówka mocy, ale zabezpieczenia wzmacniaczy i amplitunerów i owszem, zostają w tym momencie wyzwolone... :P
@Andsie
C-200 i Dune są oparte o ten sam SoC, różnice pomiędzy 8642 a 8643 są pomijalne (Macrovision). :)
No chyba że ktoś chce oglądać BD lub DVD poprzez złącze composite lub S-Video... :)
za takie coś = pełna dyskwalifikacja urzadzenia
Wykonanie miękkiego startu dla wzmacniacza buforującego to na prawdę nie jest wielki wydatek dla producenta (1-2 dolce za 2 elektrolity)
Edytowane przez mobor
A używa ktoś jeszcze wyjść analogowych ?
Oczywiście to co pisze @mobor jest prawdą, oszczędności 1-2 dolarów :)
Edytowane przez moonfall84
