janek_pl
Nowy soft do Tvix 6500/7000
[size=5][color="#FF0000"]W tym temacie nie prowadzimy żadnych dyskusji. Do tego są odpowiednie działy.[/color][/size]
Nowa wersja [url="http://www.tvix.co.kr/down/6500/tvix_M-6x00_1.1.41.fwp.zip"]1.41[/url]
Dear Customers,
Release Note
Changes from v1.1.21 (The version inside the initial shipped product)
TViX should be booted freshly before firmware upgrade for safer upgrade.
This firmware is for M-6500A only
1. Embedded subtitle support in MKV file has been stabilized.
(No image subtitle support yet)
2. Stutter when watching 24Hz movies with 24Hz output fixed.
3. Some bugs related to DTV scheduled recording have been fixed.
4. Wavepack support added (Still need more testing)
APE is not working yet.
FLAC files encoded with latest encoder are not supported yet.
WMA lossless is not supported (We are checking whether we can implement this)
5. 1000M(Giga) bit option in Network setting has been added.
You need CAT6 cable to connect M-6500A to Gigabit HUB.
We find high bit HD content plays fine with SMB connection when it stutters with 10/100 connection.
But it will play fine with NFS(Netshare or Linux PC) even with 10/100.
l The result may vary depends on the LAN environment.
Even though we used Gigabit LAN chip, the performance is slightly better than 10/100.
So, we do not advertize M-6500A as Gigabit device.
You can check the LAN mode by the LED light on the LAN JACK.
10/100 : Green
Giga : Yellow
6. Factory Default menu added in the configuration MENU.
7. Added Luminance Level menu
- Auto/ 0 ?255/ 16-235
When Auto, it will follow the information that Display device sends through HDMI.
8. Not supporting USB external DVD(CD)-ROM bug fixed
9. Problem when copying from TViX to PC using TViX as SAMBER server fixed.
Known problems and issues
1. Trick play and audio change problems still exists when playing tp(ts,m2ts..) files or large AVI files.
2. JPEG slide show and music play enhancement is under development.
3. Content with AAC audio play has some problems.
4. TrueHD and DTS HD MA pass though using HDMI is under development.
5. There is a report on compatibility with USB external storage.
6. M-6500A can be overheated and fail to work when used without installing HDD inside.
This is the problem of air flow. We are sorry but please insert HDD as dummy.
We are preparing a dummy structure that will make air flow better without the HDD.
This will be factory inserted when it is ready.
7. Some DVDs will crash when you do DVD menu navigation using DVD Juke box feature(ISO, IFO play)
8. IFO file play stutters when playing through network using Netshare. Using SAMBA is OK.
Pozdrawiam Edytowane przez janek_pl
Do pobrania nowa wersja oficjalna 1.44
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/tvix_M-6x00_1.1.44.zip"] <Pobierz 1.44> [/url]
Wgrałem osobiście i potwierdzam, że wszystko jest OK.
[b]
Zmiany od wersji v1.1.21 [/b]
implement this)
10/100 : Green
Giga : Yellow
9. m3u file playing does not work now.
10. Wrong length of MP3 VBR.
11. Some USB storage device does not work with TVIX. Edytowane przez janek_pl
Nie mogę go zainstalować.
pisze mi "error to nie jest oficjalny fw" ?
Dziwne.
Do pobrania nowa wersja 1.47
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/tvix_M-6x00_1.1.47.zip"]<Pobierz 1.47>[/url]
Do pobrnia wersja beta. Tym razem o numerku 1.2.13
[b]
Zmiany względem poprzednich wersji...[/b]
1. AVI file playback has been greately increased by RFX engine.
For the first time. We used our parsing engine rather than Sigma'
RFX(Ripped File demuXer) is the name for the our new parsing engine.
2. Tp(ts) file playback compatibility and stability has been increased.
We are changing parser for it too. It has not finised yet, it is the interim results.
So, it's not perfect. You still will be able to find a file with no audio or no video.
But it's been enhanced a lot.
3. Other minor bugs fixes.
* Dolby True HD or DTS HD MA pass-through is not supported.
Still waiting for Sigma to release correct SDK.
* AAC decoding is broken in SDK, so all the files with AAC audio will have problem.
*There is no enhancement in other areas like slide show or music play.
* We are working on it with higher priority but now we are spend time for 4100/5100 firmware too. So, please wait a little more.
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/Beta/tvix_M-6x00_1.2.13.zip"]<Pobierz 1.2.13>[/url]
Miłego testowania
Nowa wersja beta 1.2.20 do pobrania
[url="http://demod.dvico.com/user/tvix_M-6x00_1.2.20.zip"]<POBIERZ 1.2.20>[/url]
Nowa wersja beta 1.2.46 do pobrania
Lista zmian:
1) Bug related displaying subtitle fixed (M-6500A only)
2) Better readability of subtitle (M-6500A only)
3) More bugs fix in MKV embedded subtitle
4) Problems of not playing more than 5 min in some files fixed
5) More bugs fix in ICON mode
6) Added menu of Auto PAL/24Hz, NTSC/24Hz
7) Displays folder and file list as default when only network drive is used.
8) When you select second audio, second audio is still selected when next file is played automatically.
9) Other minor bugs fixed.
[url="http://demod.dvico.com/beta/tvix_M-6x00_1.2.46.zip"]<POBIERZ>[/url]
[quote name='janek_pl' post='98802' date='26.04.2008, 10:22 ']Nowa wersja beta 1.2.46 do pobrania
Lista zmian:
Pozdrawiam[/quote]
Sprzęcik będę miał na poczatku tygodnia ale z góry dziękuje koledze za ten watek :(
Z głuprzych pytań, jak to zrobić? Zgrac na pena i odpalić w urzadzeniu?
Autorus
Dopiero doczytałem ze tu nie ma dyskusji, wiec jakby co mozna skasować moj post.
Edytowane przez autorus
[b]Nowa wersja beta 1.2.51[/b]
[url="http://dvdnews.free.fr/TViX/M-6500/tvix_M-6x00_1.2.51.zip"]<DO POBRANIA>[/url]
Rozpieszczają nas ostatnio. [b]Pojawiła się nowa wersja softu. Tym razem 1.2.52[/b]
1. Better AVI file compatibility and response time by adapting our own RFX engine.
2. Font size can be changed in set up when displaying folder/file list
3. Subtitle compatibility enhanced
4. Better compatibility TS/TP/M2TS/MTS file playback
5. Bug fixes in font display
6. NTSC/24Hz, PAL/24Hz mode added
7. Fan speed control changed to 3 speed.
8. Fan will keep on rotate if the temperature is high until temperature goes low even after the power off.
?¤ No changes about JPEG and music play.
Note:
Most frequently asked hardware limitation
?¤ WMV7,8(WMV 1,2), WMV9 AP@HL not supported
?¤ H.264 support up to High@L4.0 only
?¤ MJPEG not supported
Our next top priority to-do list. ?¤ TrueHD, DTS HD MA pass-through using HDMI
?¤ Enhancement in JPEG slide show
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/tvix_M-6x00_1.2.52.zip"]<POBIERZ>[/url]
Co dwa dni nowe bety.
No ale wygląda, że to nie jest Beta bo jest w katalogu głównym.
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/"]ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/[/url] Edytowane przez dominikjestem
[b]Nowy soft BETA FW 1.3.10[/b]
Najważniejsza zmian:[size=4] suport DTS-HD TRUE-HD[/size]
Zmiany od wersji 1.2.52:
1st, HD the audio frequency Pass-through pattern may support
??i. In the establishment increased the HD Pass-through option. (this option only when is at state of activation in HDMI audio frequency output option, is at may state of activation)
??ii. known question:
????1. When HD audio frequency through the HDMI output, coaxial and optical fiber non-data output
????2nd, on the screen demonstrated information not necessarily correct
2nd, LPCM pass-through may use
3rd, AVI/MKV broadcast ability improvement
??the i.RFX engine supports multi video MKV
??the ii.RFX engine supports the non-standard frame frequency
??the iii.RFX engine reads FFDS correctly the FourCC code the document
4th, TP/TS/M2TS document broadcast performance improvement
5th, MP4 document broadcast performance improvement
6th, revised one after stopping the DVD broadcast, chooses the fence again to suppose to the first folder's on question
7th, revised one, when the document broadcast total length is unable the read, the user will press 2 time info to cause the question which the system will restart
8th, the exterior UTF8 form captions may support
9th, captions related improvement
??i. revised a ASS document to be able to demonstrate the internal label's question
??ii. Next and the Previous key may when the choice captions document's page cuts has an effect
10th, Icon pattern's some breakdowns revised
11th, involves revised to HDMI some breakdowns
??i. video frequency document cut question revision
??the ii. television system is unable the question which establishes correctly to revise
12th, some small breakdowns revised
Known question
1st, the TS document's sound track number and the frequency possibly do not have the correct demonstration
2nd, when opens HD Audio the Pass-through function, the HD audio frequency's essence not outputs through coaxial or the optical fiber
3rd, when closes HD Audio the Pass-through function, will have the HD audio frequency movie to be possibly unable to broadcast normally
4th, certain WMV document broadcast is not normal
5th, some TP document can cause the machine to restart
[url="http://rs345.rapidshare.com/files/123498516/tvix_M-6x00_1.3.10.zip"]<pobierz>[/url]
[b]Nowy soft dla Tvixa 6500-7000 1.3.21 Beta pre-release[/b]
[b]Zmiany od wersji 1.2.52 do 1.3.21:[/b]
- HD Audio(TrueHD, DTS HD MA) Pass-through through HDMI support
- There is an option for HD Pass-through. (This will be enabled only if HDMI Audio out is enabled)
2. Known issues
- When HD audio is out through HDMI, SPDIF does not output data.
- LPCM pass-through works.
3. Improved AVI/MKV file playback
- Supports embedded image subtitles. (SUB only)
- Supports non standard frame rates (other than 24,25,30,120)
- Detects s FFDS in FourCC correctly.
4. FTP server improvements
- Supports up to three sessions.
- The Timeout period has been changed to 5 min from 30 min. When the connection has not been disconnected properly. It will terminate the connection after 5min.
5. Improved compatibility of TP/TS/M2TS files playback.
6. Improved compatibility MP4 files playback.
7. Fix a bug that the focus is reset to the first folder after stop
8. DVD playing.
- Fix a bug when the duration of video files are not available, the system will crash when user press the info key twice.
- External UTF8 subtitle is supported.
9. Subtitle related bugs are fixed.
10. NowASS tags are ignored.
11. Next page and Previous page key works on the subtitle selection page.
11. Some icon mode bugs are fixed.
12. Several bugs related to HDMI fixed now.
- Screen shift in some TVs fixed.
- Unable to set TV Standard(NTSC,PAL) in HDMI mode is fixed.
13. Minor bug fixes and minor improvement
- You can put a blank by pressing 1 key in the alphabet input mode.
- By pressing 1 key, you can select from '.', ',', '?','!', ' '(blank or space).
Known issues
- Number of Channel and frequency information of TS/TP files may not correct.
- When HD Audio pass-through is on, core part of HD audio will not be output through SPDIF nor COAXIAL.
- When HD Audio Pass-through is disabled, clips with HD Audio files may not played properly.
- Some WMV files are not played properly.
- Some TP files will reboot the unit.
- Some wma files will make TViX reboot.
[url="http://demod.dvico.com/user/tvix_M-6x00_1.3.21_prerelease.zip"]<pobierz>[/url]
[b]Nowy soft dla Tvixa 6500-7000 1.3.25 Pre-release2[/b]
[b]Zmiany od wersji 1.3.21:[/b]
- Fixed DTS output through HDMI as PCM even though DTS Audio output set
as Digital
- Fixed FLAC and other audio format many not sound when the digital is
set for audio output.
- Fixed PCM is output when playing DVD with audio output type is set to
digital.
- Fixed MP3 and other audio file doe not sound after reboot.
- Fixed audio does not sound through HDMI in DTV mode.
- Fixed other minor bugs.
Known issues
- Audio channel and frequency may not correct when playing TP/TS/M2TS
files
- When HD Audio pass-through is on, SPDIF does not sound either.
- If HD Audio Pass-through is set to off, the file may not play
correctly.
- Some WMV files may not played.
- Playing some tp/ts/m2ts files cause system reboot.
- Does not support digital output for AAC ,WMA codecs.
- In some case with HDMI connection, you may see purple image. This will
be cleared when you turn off and on the display or reapply the video
output setting.
- If you play files without refreshing the file list after delete files
through FTP or SAMBA server, the system will reboot.
[url="http://demod.dvico.com/user/tvix_M-6x00_1.3.25_Pre_Release.zip"]Download[/url]
pzdr.
I Kolejna BETA 1.3.28
[url="http://rapidshare.com/files/135264580/tvix_M-6x00_1.3.28.fwp.html"]Download[/url]
Po długiej przerwie pojawiła się kolejna wersja softu oznaczona numerkiem 1.3.42. Nie ma na razie żadnego changlogu. Jak tylko się pojawi dokleję go tutaj.
[url="http://rapidshare.com/files/146076644/tvix_M-6x00_1.3.42.fwp"]<POBIERZ>[/url]
lub
[url="http://dvdnews.free.fr/TViX/M-6500/tvix_M-6x00_1.3.42.zip"]<pobierz>[/url]
Miłego testowania
[b]TViX 1.3.52 UWAGA - WCZESNA BETA[/b]
Zmiany od wersji 1.3.25
[b]- Video related[/b]
Added option for 24Hz BCS auto correction.
If you turn this on, the value of brightness is set + 11 and -12 for the contrast when 24Hz is set.
This value is reset to original after back to default TV type.
If you turn this off, the values for Brightness and Contrast will not be changed.
Several HDMI issues are fixed.
24Hz shift issue with Sony, Panasonic and other displays fixed.
Purple image problem fixed.
Now, sends the product information over HDMI.
TS/TP/M2TS files playback improved.
IMG extension is supported now.
It only works with DVD.
Need more field test.
DAT(VCD stream file type) files are now supported.
A couple subtitle issues are fixed.
Subtitles on and off with some files.
Subtitle is not shows if the line is too long.
Supports up to 10 subtitle in one subtitle file.
Fixed the system reboot problem with no menu DVD titles.
[b]Known issues[/b]
Some TP/TS information may not correct.
When HD Audio pass-through is on, S/PDIF does not output.
When HD Audio pass-through is off with HD audio stream, the playback is not smooth.
Some TP/TS files may cause the system rebooting.
Some WMV may not play correctly.
The digital output for AAC/WMA is disabled.
Does not support PCM audio track on MP4 now.
[b]Audio and Picture related[/b]
Picture playback has been improved.
Improved file compatibility.
Play without a black image between pictures.
Support a transition effect. Fade effect is supported now.
By default the slideshow effect is FADE.
You can change the slideshow delay from 0, 5, 6, 7, 8, 9, 10, 20, 30 to 60.
The maximum resolution we supports is 24M pixels.
The picture will be rotated based on EXIF.
Improved audio play.
APE is now supported.
Now, 2x, 4x play back is supported for MP3, OGG, FLAC and APE.
MP3 compatibility and sound quality has been improved.
Supports MMS protocol for WMA streaming. (ASX)
[b]Known issues[/b]
EXIF information showing is disabled.
Sometimes, the audio pitch is not correct.
The digital audio output for the background is corrupted. It works when the analog is selected.
[b]PVR related[/b]
Supports T451 DMB-TH tuner
Supports Chinese.
Fixed some channel scanning problem for Bulgaria and Romania.
General
Setup will be backed up on the local HDD so it will be restored after firmware upgrade.
This feature is only available after this firmware. This means your current setting will be reset. There must be local HDD or USB HDD to use this, so if you don't have the local disk, you should use USB to upgrade firmware otherwise, the setup may be cleared.
Setup will be saved before upgrade and every time you shutdown unit.
SAMBA server updated.
It works with Vista.
It supports international characters.
When TVIX connect to SAMBA servers, now shows international characters correctly.
It only shows based on currently selected language.
EDID_failed.ted file is not created anymore not to confuse customers.
Romanian is supported now.
Dutch change to Nederlands
Other minor bug fixes.
[url="http://demod.dvico.com/PreRelease/tvix_M-6x00_1.3.52.zip"]
<pobierz>[/url]
[b]TViX 6500/7000 1.3.55[/b]
Zmiany od wersji 1.3.52:
-Low bitrates mp3 files are supported.
All low bitrates mp3 files, of which sampling frequency is less than 32kHz, get up sampled to 44.1kHz
- Fixed a bug of occasional no sound with DTS-HD MA and Dolby Digital Plus
- Fixed a bug of incorrect sound on MPEG audio in AVI and MKV through HDMI
- Fixed occasional high audio pitch problem..
- Fixed audio does not sound through HDMI when playing DVD or
changing audio tracks of DVD.?
- Fixed occasional no audio when the unit is freshly booted.
- Fixed a problem of no MKV embedded subtitle in some cases.
- It supports Chinese station names for DTV
[url="http://demod.dvico.com/PreRelease/tvix_M-6x00_1.3.55_aa.zip"]<POBIERZ>[/url]
[b]TViX Update 6500/7000 1.3.59: Beta 3[/b]
Changes from 1.3.55
Added new options of no outline for the subtitle font to improve the showing speed.
Now, audio and subtitle will be selected on the popup.
Fixed a bug that subtitle is not shown when subtitle font size is too large.
Fixed a bug that Audio track selection does not work with mpeg/ts file types.
Fixed Dolby Digital + detection problem
Fixed DTV SPDIF audio output problem when the audio codec is MPEG
Knwon issues,
M4A files are not played correctly.
PCM track on DVD may not output through HDMI with some display.
*** If you play files with HD audio tracks like Dolby TrueHD, ,
Dolby Digital Plus, DTS-HD MA or LPCM, you better turn on HD Audio pass
through on the setup even though you don?t have a receiver that supports
decoding of these formats. Otherwise, you will hear strange noise with
some repetitive popping noise. Currently, we don?t support core
decoding, if you don?t have a HD audio decoder receiver, you need to
select other then these HD audio tracks audio track for now.
[url="http://demod.dvico.com/PreRelease/tvix_M-6x00_1.3.59_asdf.zip"]
<POBIERZ>[/url]
[b]TVIX 6500/7000 1.3.65[/b]
Changes from 1.3.59
1. The crash issue found during playback of MKV files with embedded subtitle has been fixed.
2. Different audio streams can be selected while playing AVI or MKV files.
3. The system crash issue during volume change after audio track change has been fixed.
4. Audio and subtitle key works only during Play or Pause.
5. The Issue with hard disc formatting using TVIX is fixed.
6. Users can connect to SAMBA servers with different ID and password. Earlier ID could be only “tvixhd1”.
7. Fixed audio does not output when play a PCM track on DVD with some display.
* Setup structure has been changed, so please check if the setup is preserved or not after upgrade.
Known issues
Video Issues:
1. When Auto Switch is set for NTSC/24Hz, 24Hz files may not output through HDMI with some display devices.
2. For some MKV files, TVIX crashes when it is played from bookmark.
3. For MKV files having FLAC and OGG audio stream, the audio is muted.
4. For some MKV files, the subtitles displayed are not in sync
5. For some TS files, resuming normal playback after fast forward playback, leads to muting of the audio.
6. For some TP files, the audio stutters and sometimes crash is also observed.
7. For TS, TP, M2TS and MTS files, fast backward playback is not supported.
8. Play an M2TS file with DTS HD master audio.
When DTS audio setting is digital, HDMI audio is ON and HD audio passthrough is set to ON, then audio is not heard on the SPDIF output.
For the same setting, if HDMI audio is set to OFF, then audio is HEARD on the SPDIF output.
Audio Issues:
1. If you play files with HD audio tracks like Dolby TrueHD, Dolby Digital Plus, DTS-HD MA or LPCM, you’d better turn on HD Audio pass through on the setup even though you don’t have a receiver that supports decoding of these formats. Otherwise, you will hear strange noise with some repetitive popping noise. Currently, TVIX doesn’t support core decoding, if you don’t have a HD audio decoder receiver, you need to select other than above HD audio track.
2. Some of the AAC files are not being played back.
3. MP4A files are not being played back
4. For some APE and OGG files, the audio is muted
5. For MP3 files with low sampling frequency, the TVIX crashes on playback from a specified time.(GOTO playback)
6. For MP3 files with low sampling frequency, the TVIX crashes on fast forward playback
ETC Issues:
1. USB icon continues to display even after disconnecting DVD-ROM USB drive from TVIX. Then clicking on the USB icon leads to crash of TVIX.
[url="http://demod.dvico.com/prerelease/tvix_M-6x00_1.3.65.zip"]<POBIERZ>[/url]
[b]TVIX 6500/7000 1.3.74[/b]
[url="ftp://ftp.dvico.com/Products/TViX/Firmware/M-6500/Beta/tvix_M-6x00_1.3.74_Beta.zip"]<pobierz>[/url] Edytowane przez janek_pl
od 13.12.br wersja oficjalna:
[url="http://www.tvix.co.kr/Eng/Support/M6500AFirmware.aspx"]http://www.tvix.co.kr/Eng/Support/M6500AFirmware.aspx[/url]
[b]Changes from 1.2.52[/b]
• Video related
• Several bugs related to HDMI fixed now.
1. Screen shift in some TV fixed.
• Improved AVI/MKV file playback
○ Supports non standard frame rates (other than 24,25,30,120)
○ Detects s FFDS in FourCC correctly
• Supports embedded image subtitles on MKV files (SUB only)
• HD Audio(TrueHD, DTS HD MA) Pass-through through HDMI support.
○ You can turn on/off on the setup.
○ This is only possible with HDMI 1.3 receivers which support these codec.
○ If you don't have these kind of device, you must turn off.
• LPCM pass-through works.
• Now, when you press the audio or subtitle key, the track selector will be shown.
• Improved compatibility MP4 files playback
• Added option for 24Hz BCS auto correction.
○ If you turn this on, the value of brightness is set + 11 and -12 for the contrast when 24Hz is set. This value is reset to original after back to default TV type.
○ If you turn off this, the values for Brightness and Contrast will not be changed.
• Several HDMI issues are fixed.
○ 24Hz shift issue with Sony, Panasonic and other displays fixed.
○ Purple image problem fixed.
○ Now, sends the product information over HDMI.
• TS/TP/M2TS files playback improved.
• IMG extension is supported now.
○ It only works with DVD.
• DAT(VCD stream file type) files are now supported.
• A couple subtitle issues are fixed.
○ Subtitles on and off with some files.
○ Subtitle is not shows if the line is too long.
○ Supports up to 10 subtitles in one subtitle file.
• Fixed the system reboot problem with no menu DVD titles.
• Fixed sometimes MKV embedded subtitle is not shown.
• Subtitle supports improved and several bugs are fixed
○ External UTF8 subtitle is supported
○ Does not show ASS tags anymore
○ Now the maximum external subtitles in one file is 5 instead of 10.
○ Added new options of no outline for the subtitle font to improve the showing speed
• Known issues for Video related
• Some TP/TS information may not correct.
• When HD Audio pass-through is on, S/PDIF does not output.
• When HD Audio pass-through is off with HD audio stream, the playback is not smooth.
○ When DTS audio setting is digital, HDMI audio is ON and HD audio passthrough is set to ON, then audio is not heard on the SPDIF output.
○ For the same setting, if HDMI audio is set to OFF, then audio is HEARD on the SPDIF output.
• Some TP/TS files may cause the system rebooting.
• Some WMV may not play correctly.
• The digital output for AAC/WMA is disabled.
• Does not support PCM audio track on MP4 now.
• Some low sampling frequency on AVI and MKV may not sound on HDMI.
• When Auto Switch is set for NTSC/24Hz, 24Hz files may not output through HDMI with some display device
*** If you play files with HD audio tracks like Dolby TrueHD, , Dolby Digital Plus, DTS-HD MA or LPCM, you better turn on HD Audio pass through on the setup even though you don’t have a receiver that supports decoding of these formats. Otherwise, you will hear strange noise with some repetitive popping noise. Currently, we don’t support core decoding, if you don’t have a HD audio decoder receiver, you need to select other then these HD audio tracks audio track for now.
• Audio and Picture
• Picture playback has been improved.
○ Improved file compatibility.
○ Play without a black image between pictures.
○ Support a transition effect. Fade effect is supported now.
§ By default the slideshow effect is FADE.
○ You can change the slideshow delay from 0, 5, 6, 7, 8, 9, 10, 20, 30 to 60.
○ The maximum resolution we supports is 24M pixels.
○ The picture will be rotated based on EXIF.
• Improved audio play.
○ APE is now supported.
○ Now, 2x, 4x play back is supported for MP3, OGG, FLAC and APE.
○ Low bitrates mp3 files are supported now.
§ All low bitrates mp3 files, of which sampling frequency is less than 32kHz, get up sampled to 44.1kHz
○ MP3 compatibility and sound quality has been improved.
○ Supports MMS protocol for WMA streaming. (ASX)
• Known issues for Audio and pictures playing
• EXIF information showing is disabled.
• For MP3 files with low sampling frequency, the TVIX might crash while playing or trick play like FF or RW.
• PVR
• Supports T451 DMB-TH tuner
• Supports Chinese.
• Fixed some channel scanning problem for Bulgaria and Romania.
• Supports Chinese station names.
• Known issues for PVR
• After channel changed, you may not here audio in short time. This is the bug from the chip manufacturer. To solve this, you can press DTV key or Audio key on the remote.
• General
• FTP server improvements
○ Supports up to three sessions.
○ The Timeout period has been changed to 5 min from 30 min. If the connection is not been disconnected properly, It will terminate the connection after 5min
• Setup will be backed up on the local HDD so it will be restored after firmware upgrade.
○ This feature is only available after this firmware. This means your current setting will be reset.
○ There must be local HDD or USB HDD to use this, so if you don't have the local disk, you should use USB to upgrade firmware otherwise, the setup may be cleared.
○ Setup will be saved before upgrade and every time you shutdown unit.
• SAMBA server updated.
○ It works with Vista.
○ It supports international characters.
○ You can change the ID and password for the samba server.
• Normal Upgrade speed will be improved after upgrade this version.
• You can put a blank by pressing 1 key in the alphabet input mode.
○ By pressing 1 key, you can select from '.', ',', '?', '!', ' '(blank or space).
• When TVIX connect to SAMBA servers, now shows international characters correctly.
○ It only shows based on currently selected language.
• EDID_failed.ted file is not created anymore not to confuse customers.
• Next page and Previous page key works on the subtitle selection page
• Some icon mode bugs are fixed
• Romanian is supported now.
• Dutch change to Nederlands
• Other minor bug fixes.
• Known issues for general issues.
• If you play files without refreshing the file list after delete files through FTP or SAMBA server, the system will reboot.
Zdaje się że nowa beta pozwoli na przełączanie ścieżek audio i napisów w BD ripach... :(
[url="http://www.mpcclub.com/modules.php?name=Forums&file=viewtopic&t=19878&postdays=0&postorder=asc&start=0"]http://www.mpcclub.com/modules.php?name=Fo...asc&start=0[/url]
TViX Update Beta 1.3.95
Zmiany od wersji 1.3.74,
DTV
1. Some channel scan problem fixed
2. The shceduled recording bug fixed.
File player
1. HDMI parts are updated for various problem.
2. Improved avi playback.
<pobierz>
