Remi_K
Nowy Firmware A200
http://www.popcornhour.com/download/A200/0...19-POP-411.html
Release Date : 14 May 2010
Firmware Version : 02-02-100428-19-POP-411-000
Release Note :
1. Minimum NMT apps 02-02-100318-19-POP-411
2. BD/AVCHD/DVD/CDDA
- external SRT subtitle support for BD
- Put SRT file (same name as BD title folder name/ISO name) at same directory level
- Start main movie playback, then use SUBTITLE key to toggle embedded/external SRT subtitle.
- Fixed some DVD disc playback on NTSC & PAL mode, cannot restore composite output after playback (Bug #5000407)
- Fix volume up/down, audio muted (Bug #5000401)
- Added handling for BD initial audio/subtitle language settings according to setup
- Save/resume bookmark support - currently not persistent (only saved to volatile memory)
- Disabled non-functional ZOOM/PAN key BD-J playback.
- Fixed playback via SMB crash with certain file (Bug #5000457)
- Fixed audio track swicthing failure on first keypress of Audio key (Bug #5000464)
- Fixed initial language/subtitle setup doesnt work with BD disc (Bug #5000492)
- Fixes for BD/DVD parental control function
- Fixed for external SRT subtitle font size during BD playback (Bug #5000489)
- Fixed certain BD subtitle cannot display
- Fixed PCM via HDMI audio loss after DVD playback (Bug #5000272)
- Optimise external SRT support (word-wrap etc)
- Fixed for audio out-of-sync for BD playback after adjust audio offset
- Persistent bookmark/resume for BD on harddisk
- Fixed SimpleBD time seek inconsistentcy in certain cases
- Fixed external SRT cannot display Hebrew properly, broken in previous RC1
- BD navigation method now selectable (Setup -> BD/DVD/Audio CD: BD Navigation)
- File View: basic file browsing
- Simple BD: simplified BD navigation
- AVCHD + SimpleBD: AVCHD and simplified BD navigation
- Full Navigation: Full BD navigation
- Fixed certain titles show wrong elapsed time in SimpleBD mode
- Fixed select different audio track at SimpleBD Menu will cause playback to wrongly skip ahead by > 1 hour (Bug #5000460)
- Fixed shuffle icon not displayed on front panel when in Audio CD shuffle playback (Bug #5000540)
3. Video and Audio playback
- Fixed HDMI audio cannot recover after turning TV off and on again (Bug #5000032)
- Changes for MP4 HTTP streaming, for better key responsiveness and buffering.
- Fixed Dolby Digital DRC setting not applied properly
- Fixed audio stuttering in certain MP4 clips (Bug #5000377)
- Fixed certain TS file cannot get width/height and aspect ratio when resume from bookmark.
- use 1920x1080 resolution for subtitle rendering
- Marquee window for BGM displaying brief ID3 info
- Fixed crash if MKV chapter name is too long
- Fixed stuttering in certain MP4 (Bug #5000456)
- Fixed font size in certain SSA subtitle
- Subtitle pos Y adjustment; Added timeout (20sec) to clear OSD menu after idling
- myihome and WMP11 streaming failure; broken in previous release
- Fix for TV recorded TS stream
- Changed audio sync adjustment; now 10 msec per step with -2sec ~ +2sec range
- Fixed FLAC (96kHz/24bit) playback have no audio output on certain HDMI TV (Bug #5000434)
- Fix for TV recorded TS stream with PMT > 0 could not playback
- Save on-the-fly "audio sync" setting persistently
- Fix for standby mode during video/music playback (Bug #5000458)
- Fixed incorrect TV mode display on infobar when set to HDMI/Component 576p (Bug #5000461)
- Fixed no subtitle display with certain MKV (Bug #5000409)
- Fixes for certain mkv and mp4 playback stuttering or audio loss
- Fix MIB clip freeze and audio jitter for TrueHD core
- Fixed Scaling/Zooming/Panning issue when in SD TV mode
- FIxed certain SSA not displayed with user-selected ANSI codepage
- Removed non-functional Hue setting from Video-Setup menu
- Fixed external .srt and internal PGS subtitle for M2TS format overlapped (Bug #5000503)
- Fine-tuning of mp4 playback performance
- Fixed volume setting always reset to 0 after rebooting (Bug #5000406)
- Patch for certain MOV file recorded by Canon EOS1D Mark IV DSLR cannot playback
- Playlist navigator for music playback (first phase)
- press Green button during music playback (not available for BGM)
- only simple navigation (up/down, Enter keys) now, press Green to close or timeout after 20sec
- not applicable with UPnP or HTTP-based server
- Fixed music playlist navigator cannot display after BD playback
- Fixed subtitle menu inconsistency when subtitle if set off by default
- Fixed Arabic Tashkeel shaping error in subtitle (Bug #0000272 part1)
- Fixed displaying of "0.wav" on front panel bug of previous RC2
- Fixed black screen display when playback ended during playlist navigator mode
4. Photo app
- Fixed player freezed upon playing certain corrupted image (Bug #5000424)
- Pressing Power key will stop slideshow and goto 'standby'
5. System/Network
- Corrected Dolby disclaimer
- Unique USB device names for repeated names
- Setup
- Adjustment for page layout in SD mode
- Fix for BD PiP and parental control level settings saving issue
- Fixed DVD setup page settings cannot update if parental password wrong or canceled
- minor modification of layout and translation
- Fixed BD PiP and BD Navigation does not restore when default factory setting selected
- Network listing navigation page up/down using front panel key
- Added TCP receive window size adjustment (in Setup -> Network)
- value between 1500 and 32000 bytes
- Persistent saving of subtitle color, fontsize and pos setting
- SATA Hotplug support
6. Browser
- Fixed File copy issue with certain USB device
- Delete one file should show 1/1 on osd instead of 0/0
- Fixed rename folder fail and cannot see original name on popup
- Fixed file operation problem with '?' or '$' in filename
- Language pack translation and pop-up message word wrap fix
- Hotplug USB-HDD OSD message fix
- SATA Disk volume label if applicable.
7. Torrent
- Fixed scheduler UI refresh issue
- Torrent setting page UI misalignment fix (Bug #5000462)
8. PHF (ROBIG)
- Fixed flashapp missing images
- Added new PHF apps: channelcom, nextnewnetwork, malaysiakiniTV
- Fixed volume control jump two steps
- Fixed mp3 sound issue where it stops after 2 sec
- Improved font display (e.g. some characters truncated)
- Pressing Power key will stop PHF and goto 'standby'
- Fixed when PHF with music is playing in the background, start an music playback will cause crash or vice-versa
- Fixed some characters truncated vertically
- Fixed an issue related to Photobucket where one GIF crash upon decoding
9. NMT Apps
- NMT apps install to USB device. Separate NMT apps installation from Media partition.
- Fixed various issues after new NMT installation introduced in previous release
