paw
Twoje HTPC z DTS HD MA
[img]http://hdtvpolska.com/news/news-shadow.png[/img]Asus zapowiada wprowadzenie do swojej ofery combo karte odpowiadającą za grafikę i dźwięk z HDMI 1.3 dzięki czemu będzie możliwe wypuszczanie nowych fromatów dźwięku.A sama kart bez problemów ma radzić sobie z blu-rayem.
Niestety ceny nie znamy.
Tekst oryginalny:
Asus unveiled at Computex the Xonar HDAV1.3, the world's first HDMI 1.3a compliant audio/video combo card.
The board is capable of outputting uncompressed multichannel high definition audio from Blu-ray movies, while it also enhances video with an onboard Splendid HD processor.
This means that users of desktop systems that don't have a discrete graphics card or a high-end CPU can enjoy Blu-ray movies and high definition sound by installing one card into their computers.
The Xonar HDAV 1.3 features Protected Audio Playback Systems (PAPS) and full Advanced Access Content System (AACS) certification. Without both of these certifications, typical PCs will need to downsample Blu-ray audio to DVD quality (48K/16bit). By working with ArcSoft's Total Media Theater, ASUS' Xonar HDAV1.3 is capable of decoding Blu-ray movies and takes full advantage of lossless digital audio formats such as Dolby TrueHD and DTS-HD Master Audio for high-fidelity sounds at 24bit, 96-192Khz. The PCI Express based Xonar HDAV1.3 is designed from the ground up for next generation home theater PCs (HTPC); and is equipped with the proprietary AV200 audio processor and HDMI1.3a certified Splendid HD video processor ? making it capable of delivering the highest quality 7.1 channel 192K linear pulse code modulation (LPCM) audio and high definition video through the HDMI port.
The ASUS Xonar HDAV1.3 also reigns in analog audio quality thanks to a HyperGrounding circuit design. With HyperGrounding, Xonar sound cards further reduce EMI noise inside modern PCs, providing clean 120 dB SNR and peerless 0.0004% low distortion. Unlike generic audio cards in the market that provide the highest SNR to only the front stereo outputs, the Xonar D2X is able to deliver 120 dB quality audio for all 7.1 channels.
The Splendid HD Video Processor increases color performance and enhances edges for crisper high definition image without impacting the CPU load.
At the heart of the Xonar is an ASUS AV200 codec chip, which routes and interprets high quality signals to audio components. These materials include oversampling digital to analog converters (Burr-Frown PCM1796, 123 dB SNR), National Semiconductor LM4562 operational amplifiers (opamp), and analog-to-digital (Cirrus Logic CS5381, 120 dB SNR) converter. The Xonar HDAV1.3 is the first in the Xonar family to utilize opamp sockets to allow simple, solder-less modifications for user-customized sound.
The Xonar HDAV1.3 also comes with the DS3D GX 2.0, which revives EAX 5.0 and 3D gaming audio in Vista. DS3D GX 2.0 automatically enables the latest EAX and DirectSound HW after installation, with no additional driver patches, game modifications, or OpenAL required. DS3D GX2.0 also extends MMOG EAX to online chat, allowing you to place your voice into the game's environment.
[url="http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=23426"]http://www.cdrinfo.com/Sections/News/Detai...px?NewsId=23426[/url]
ASUS did not comment on pricing and availability for the HDAV1
[img]http://www.blogsmithmedia.com/www.engadget.com/media/2008/06/6-4-08-xonar-hdav1.3.jpg[/img]
[img]http://www.blogsmithmedia.com/www.engadget.com/media/2008/06/6-4-08-xonar-hdav1.3-deluxe.jpg[/img]
Edytowane przez paw
Jest też szansa na prostsze a równie efektywne rozwiązanie - plotki mówią o LPCM 7.1 na nowej serii kart AMD HD48xx , byleby tylko Cyberlink udostępnił opcje dekodowania każdego sygnału do LPCM po bezpiecznym torze dźwięku (jeśli taki będzie) na kartach AMD. W takim przypadku nie dość że wystarczy starszy amp z HDMI to mamy zgodność z advance profile czy jak to się tam zwało. :)
no cenny aktualnie to porażka bardziej opłaca się kupic ps3 czy samsunga bd-p1400 niż karte dźwiękową i najtanszy wewnetrzny blu-ray do kompa:(
Wow. Ile trzeba było czekać, aż producenci się obudzą i dodadzą obsługę dźwięku do HDMI? 3 lata? :)
[quote name='jacek1969r' post='105684' date='05.06.2008, 20:25 ']Tylko PCIExpress x1 dla tego potworka?[/quote]
A po co więcej???
PCIExpress x1 potrafi przesyłać 250MB/sekundę!
Nawet gdyby przesyłać 7(siedem) 24-bitowych kanałów z próbkowaniem 96 kHz (bez żadnej kompresji) to potrzeba ..... 2 MB/sek :)
A tu źródło [url="http://www.asus.com.tw/news_show.aspx?id=11638"]LINK[/url] , czyżby nawet Asus się walnął "Burr-Frown" ??? :P
Trochę lipa przy takim rozwiązaniu 2 x PCI-E zajęte, co gorsze blisko grafiki, w każdym razie dobrze że będzie wybór : Asus, Auzentech i może AMD.
[quote name='Fantom' post='105689' date='05.06.2008, 21:50 ']A po co więcej???
Nawet gdyby przesyłać 7(siedem) 24-bitowych kanałów z próbkowaniem 96 kHz (bez żadnej kompresji) to potrzeba ..... 2 MB/sek :P[/quote]
Sorry myślałem z początku że ma normalną grafę 3D na pokładzie. Dopiero po napisaniu posta wczytałem się w specyfikację.
Tak przy okazji, to jak toto działa w przypadku "Gaming" i co to niby daje?: [quote]Splendid HD Modes -Photo, Video, Gaming (Gaming mode requires ASUS graphics card)[/quote]
Edytowane przez jacek1969r
Czy dekodowanie filmów na płytach blueray jest tym samym co dekodowanie plików na dysku z materiałem HD: divx, .mov, .mkv,.avi? Czy ta karta też będzie dekodowała te rozszerzenia? Edytowane przez kruczy
[quote name='apatch' post='105727' date='06.06.2008, 06:23 ']A tu źródło [url="http://www.asus.com.tw/news_show.aspx?id=11638"]LINK[/url] , czyżby nawet Asus się walnął "Burr-Frown" ??? :)
Trochę lipa przy takim rozwiązaniu 2 x PCI-E zajęte, co gorsze blisko grafiki, w każdym razie dobrze że będzie wybór : Asus, Auzentech i może AMD.[/quote]
pisalem o tym juz dawno....
na burrach jest juz poprzednia karta asusa
Powtarzasz się Demek a to staje się już naprawdę nudne , zalinkuj chociaż i skieruj takie uwagi do twórcy postu a nie do mnie, rozumiem że o Burr-Frown'ach też pisałeś. :)
wiem, ze sie powtarzam ale ten asus to nic nowego....
a dlaczego moze odtwarzac dzwieki HD?
bo jest zgodna z PAPS (Protected Audio Playback Systems) i AACS (Advanced Access Content System)
karty bez zgodnosci powinny konwertowac do 48/16
co do poprzedniej karty
[url="http://www.asus.com/products.aspx?modelmenu=2&model=1989&l1=25&l2=150&l3=0&l4=0"]http://www.asus.com/products.aspx?modelmen...p;l3=0&l4=0[/url]
Audio Processor
ASUS AV200 High-Definition Sound Processor (Max. 192KHz/24bit)
[b]24-bit D-A Converter of Digital Sources:
TI Burr-Brown PCM1796 *4 (123dB SNR, Max. 192kHz/24bit)[/b]
24-bit A-D Converter for Analog Inputs:
Cirrus-Logic CS5381* 1 (120dB SNR, Max. 192kHz/24bit)
Chodziło mi o link gdzie już o tym wcześniej pisałeś ale nie ważne ...
Te karty jak dla mnie to przerost formy nad treścią HTPC to z takimi molochami to przegięcie ale wiem że i tak znajdą się chętni na nie. :)
no tak, bo o ile z obrazem problemu nie ma
to ceny zeby cieszyc dzwiekiem HD zabijaja...
A [url="http://www.anandtech.com/tradeshows/showdoc.aspx?i=3328"]TU[/url] już pierwsze odpalenie, chyba będzie trzeba się przyzwyczaić do nowego playera TotalMedia Theater niestety problem w tym że jest jeszcze bardziej kapryśny w działaniu niż PowerDVD.
sadze, ze powerdvd bedzie wspierac ta karte szybko
TMT dziala jako pierwsze bo ich asus wybral, zapewne zaspiewali najnizsza cene :P
